turbobitt
- Feb 14, 2002
Looking for some ideas in remote mounted water pump mounting. I just got my Meziere remote pump and now need to mount it. I used my old Meziere pump housing as an inlet and made a plate where the old motor once was. I'm doing this because my new compressor housing will hit the pump motor.
I'm going to see if I can make a bracket and mount it as close to the radiator lower hose as possible but the frame jogs inward and also has the idler arm in the way so may be challenging. I also been considering mounting directly in the middle of the lower radiator support just behind the radiator if all else fails.
FWIW - my fans are mounted in front of the radiator so they are not in the way.
Allan G.
Allan G.
