What's the trick for removing the water pump pulley if you dont have air tools ?
I got a set of Jasons aluminum pulleys (Water & alt). I took care of the alt pulley & started the spring cleaning , removed the IC and alternator to clean up. When I went to remove the water pump pulley I realized I had a problem. I should have cracked the bolts before taking everything off
If everything is back together will I be able to break the bolts loose with the belt back on ? Im afraid there wont be enough tension and the pulley still slip....
