Replacement fuel lines still avail from GM?
cam69ss
Turbo Member
Hello,
I am looking for replacement main and return fuel lines for an '87. They are hardlines that run the length of the chassis and at the end of the line there is an attached rubber line. Does anyone know if GM still stocks them and if so what are the part numbers? I called Inline Tube and they said that they can not reproduce the hard lines with the attached rubber line. I will try Classic Tube next. Does anyone know where replacements can be purchased?
Thanks,
Dan
Don't those chassis lines simply have the rubber hoses clamped on the ends of them were they join up to the lines from the tank?
The only lines I know of that have rubber hose incorporated into them are the fuel rail supply and return lines that go on the motor.
GM does not have any fuel lines for these cars.
