novaderrik
- May 12, 2004
jack the car up as high as you can and put it on a set of good jackstands.. take the shock out... unhook the tie rod, and loosen up the lower balljoint nut a few turns... hit the spindle with a few nice manly swings on a real hammer next to where the balljoint stud goes thru until it pops loose... place a good floor jack (a real one, not a $20 AC Delco branded Chinese junk one from Wal Mart) under the lower balljoint and take the pressure off the balljoint... remove balljoint nut and slowly lower the jack... at some point, the spring will almost fall out- a pry bar will knock it loose and it will fall straight down to the ground.
install is all those steps, only backwards. the hardest part is getting the spring to seat in the pocket in the frame and catch on the lip in the control arm, but once it does it takes less time to button that side back up than you just spent reading this post..
