I am looking for max lift you can run on a stock exhaust guide with a stock valve spring retainor. 204/214 cam that is very popular has exhaust lift of .472 at the valve. By my measurements on a spare head this going to cause the retainor to hit the guide. Can I have the machine shop take a little off the bottom of the retainor?
If I have to cut the guide,then I am going to need 6 new exhaust valves.
I've seen machine shops use retainors that are thicker than stock.
I know I have a few motors I need to check over....and I thought that only when going roller the exhaust guides need to be cut and valve changed.
