I've been looking at the ATSG manual trying to decipher the pressure regulator system but I'm having a little difficulty.
I understand that the reverse boost valve biases the pressure regulator in rev, 1st and 2nd gears but does the reverse boost valve act on the PR system at any time the transmission is in reverse, 1st or 2nd gears regardless of shifter position or does it only become active if the shifter itself is in the R, 1st, or 2nd positions?
It seems from the diagrams that TV boost would overide the reverse boost valve at larger throttle openings. If that's right, why use the larger reverse boost valve if you have the large (.570) TV boost valve? If that's wrong, please help me understand the relationship betwen the two.
Charles Brooks
Charles Brooks
