well i started going together with my latest creation. i have fortified this turd in every way i could. i bought a set of ATR H beam rods with L19 bolts and as the title says, the #1 rod bolt hits the main oil pick up galley in the block. anybody ever run into this problem? it is only the outside bolt. i really dont want to grind on the block because it looks pretty thin. and i dont want to grind on the rod bolt because it would be my luck that it would break later on. i wonder if they(ARP) offers a domed head rod bolt with internal hex or torx drive? any info will be great. thanks, jeremy walters
