Twice when spinning the tires hard the eng. has backfired and quit running and will not idle, If I get the car restarted and unplug the cam it will run ok . Rechecked the cam sensor and it is out of adjustment , WAY OUT . I tried a diff cam sensor after the first time and the same situation happened again , hard tire spin ,backfire and the car will not run barely idle until I get the cam sensor unplugged .
Could the cam sensor itself be moving ? I checked the tang on the ring and it is not broken . Could the gear on the ROLLER CAM be the problem ? Jumping teeth? Gear come loose from the keyway? I may be hitting the rev limiter and that is why it backfires all of the sudden , could the backfire move the cam sensor ?I checked both cam sensors over and seen no problems with them .
Mark
Mark
