I recently had my motor rebuilt, and decided to go with a roller setup. The motor sounded great after the first hour or so of idle time. Shortly after, it developed what I believe to be a lifter ticking. It is very noticable at idle and any rpm under 1800. I've done several valve adjustments and have been ablet to quite it, for short amount of time(5min), and then it comes back. This is a Comp kit, and I know they are known to have problems with the lifters sticking.
I'm running 20w-50 oil, in case someone asks. I have also cut open two filters now, and have seen very very little metal in both. The motor has about 4 hours runtime and 70 miles.
My question is; can you damage a roller cam, if you have a gunked up lifter? The sound is just horrible to me. I can deal with the "sewing machine" noise, but this has got to be more than what you expect a roller to sound like.
