Mike Licht
I was here first
- May 23, 2001
what is your lifter preload?
Mike
Mike
SignUp Now!injecter tick ..I WISH...is it possible that these new comp cam lifters are a little gumed upped from the company??????????????
Have you checked preload since it has be run?
Mike
Why cuz of the noise?
How often are you re-adjusting the lifters?
Yep. I don't like the noise.
When the weather is very cold outside I keep them a little loose so it doesn't hold the valves open when the engine is 25-30*. When its hot outside I close them up a little. So about every 3 to 4 months is about right for a re-adjust. Seems to work for me anyhow...
Yeah but with the tall valve covers and heater/AC still in the car, isn’t it a pain pulling the pass side cover every 3-4 months? I'm asuming you have to remove the rubber lines from the heater core and swing the anti-freeze hardlines (running across the intake) out of the way just to get that cover off, right?
It's not going to kill you to do them every 3 to 4 months...![]()
I have about 1oo miles on the motor now ...the rollers are much quieter
Turbo1dr with that solid roller how often do you have to valve adj.
and is there any special parts to buy when going from a hy roller to solid thank.
