Ok so heres the deal, because now we are confusing people, and anybody can agree or disagree with me, but this is fact.The valve duration does not physically change with rocker ratio increase,it only has the valve lifted farther off of the seat at a given lift point,in other words, if you have a 1.5 rocker ratio and you change to a 1.6 ratio the valve will be farther off the seat at that same lift point for the 1.6 than for the 1.5, but the duration DOES NOT physically change with a ratio change.You cannot physically change the duration that the cam was ground at, it will still leave the seat and return to the seat at the same crank degrees no matter what ratio you have.The valve curtain area will change but not the true duration.Now that isn't to say that the engine wont like the change but it still doesn't change the physical duration of the cam.So if you are like 90% of the guys on this board who aren't total pros at this and do it for a living then call a pro tell him what you are trying to achieve and get a cam that is right for your combo and then turn up the boost to reach your goals.
