SignUp Now!Always worth checking with a degree wheel to know for sure if you're advanced or retarded or to set the cam timing exactly where you want it. I've seen a couple degree variance among timing sets.
BPE2013@hotmail.com
You would have to have baseline info before you would know if you were off by 2 degrees. Like you used the degree wheel before you removed the old chain. The difference in power is marginal. It would have to be a hard running combo for 2 degrees to matter muchIf the cam was off by 2 degrees advance or retard what kind of HP gain or loss would I see?
and make sure you get rid of the flap on metal inside the timing cover on the cam sensor bore. It you're running a GM cover that can contact a rollmaster.
No idea. I've never ran a rollmaster timing chain on any of my personal builds. I've just read over the years that the rollmaster can contact that flap. A Felpro gasket is much thicker than a GM gasket so that might be a saving grace if you're using the TCS45930 gasket kit.
