Rotaling assembly . 20 over J & E pistons
GNXJohn
Rotaling Assembly . 20 J & E pistons standard crank,rods re conditioned,assembly balanced, with balancere & flywheel, low mileage. 700.00 oba
What was the combo? What boost? What fuel was used? Any detonation evidence? What shop balanced it? Full floating? What ring sizes?
I bought rotating assemb. to build a short block, bought it off a board member, don't have the combination he ran. decided not to build it and bought a stroker motor.It is rods piston & crank, balanced assembly, you can run whatever combination you want.
Im trying to figure out if its worth it. If the parts were detonated then its probably not worth it even if they have 5 miles on them. If you/he had a mild combo with stock heads, small turbo, low CR and ran high octane gas with them id be all over it. Do you have any pics?
This rotating assemly was in a stage I with iron heads and a 61 turbo. Allways had race gas and never detonated. Parted the engine out due to no one wanted the long block. Block was O-ringed and all work was done by old man Weber 10 years ago. Previos owner was going with a new head combination.
http://www.turbobuick.com/forums/pa...lock-rotating-assembly-champ-inake-heads.html
$650 shipped? Paypal ready
