vacuum 6
- Jan 6, 2006
Does anyone make replacement rubber fuel lines (sender to the hard lines)?
SignUp Now!Here you arePost pics please.
Is that small section on the factory feed/return under the power steering alcohol compatible?In the past, we always made sure any rubber fuel line replacement for a TR was specified for fuel injection use because it is subjected to much higher pressures than a carb application.
Now we are very careful to use rubber fuel injection hose that is also alcohol resistant.
Areas around the country have pump gas with 10-15% alcohol which over a period of time will also erode rubber.
With e-85 conversions we have seen very rapid erosion of the older lines and especially braided lines that are not alcohol resistant.
Any decent auto parts supplier will have the proper hose in various sizes to fit your application.
