GNVYUS 1
- Dec 15, 2002
I looked through the search features and there hasn't been a good discussion on this in many many years. I have been reading more and more non and intercooled forced induction cars going to pre turbo/supercharged injection combo's and was curious at some of the data ( didn't find any supercharged data but didn't want to leave them out ).
Here are some things I noticed in some of the data logs I've read on this. Running distilled water at high pump pressures increased turbo efficiency and guys were able to run less psi to make the same power if sprayed pre turbo. It appears as if the M2 or M3 nozzle helps the compressor wheel dissipate heat ( like running in cold weather does over the winter ) and spool faster. For us northern guys, you notice a big boost spike in winter, generally 3psi here on the same MBC settings due to a denser inlet air charge.
So, for smaller turbo guys like me this seems like a way to stretch the comp wheel even further regardless if I already run Meth post turbo. A post I read showed some tip corrosion after 7k miles when injecting 2.7% of your inlet air mass with water. This though could have been lessened if he injected the water later in the boost sequence instead of right away and ran a higher pump pressure. It seems pointless to spray prior to 15psi but 75% of max boost seemed to be the better option to delaying corrosion and surging.
Here are some specs I found
Methanol
Density 0.7918 g/cm³, liquid
Melting point –97 °C, -143 °F (176 K)
Boiling point 64.7 °C, 148 °F (337.8 K)
Isopropyl
Density 0.786 g/cm³, liquid
Melting point -89 °C, -126 °F (185 K)
Boiling point 82.3 °C, 179 °F (355 K)
Water
Density 1 g/cm³, liquid (4 °C)
Melting point 0 °C, 32 °F (273.15 K)[2]
Boiling point 100 °C, 212 °F (373.15 K)[2]
As you go from Meth to Water the gains reduce but you lessen possible compressor corrosion.
I noticed that guys liked to run distilled water to further lessen the corrosion aspect, but from the info above it's the worst performer in the pre turbo situation. I'd be concerned with it not being a fine enough mist and damaging the comp wheel due to it's density and higher boiling point. But later read that running pump pressures into the 150+ range on small nozzles cures this issue with mists in the 20 micron range being possible.
Then there was an old school Dodge Turbo using Isopropyl and 50k miles later spraying it around peak turbo psi had no compressor corrosion with great results. This seems like the winner to me at 150+ psi on a nozzle matched to your mass air intake.
What's your take, we're all greedy when it comes to power and Isopropyl pre turbo seems to be the ultimate cold air kit IMO.
Methanol
Isopropyl
Water
