Running richer all of a sudden
turbosam6
My cars suck
Hooked the laptop up last night and cruised around town a bit, and my actual A/F ratio was a lot richer than last time I checked. I was around 14:1 cruising under light throttle, now its like 12:1. WTF happened? I did change my DP to a 3.5" from a 3", but that would not cause it to run rich. The 02 sensor is located slightly differently than my previous dp, just a couple inches, shouldn't matter.
Any difference at WOT? I wouldn't worry about part throttle unless it's giving you drivability problems.
Check the air temp sensor on the dashboad and make sure it doesnt read - degrees, If the sensor goes bad it will make the car run richer
