RU's new DD, "The Red Baron".
There is three holes in the core support about 3" that need to be cut and the battery needs to moved to the trunk. It is not near as bad as the APS. Check out the L92 heads from the Escalade $180 each bare, 330CFM with a decent valve job, no porting. L76 intake comes with 39 lb injectors and a 90MM throtttle body for under $500 that bolts on those heads
Mike
Mike
Mike, please keep us updated on your car as it progresses. I've been considering the L92/L76 set up for quite some time... The whole turbo thing has been pretty appealing too, but it's way out of my price range right now, when you consider all of the additional upgrades that would have to follow!
