Dec 22, 2008 #1 M melrob94 Member Joined Dec 14, 2006 Messages 161 How do these numbers look at idle and warm? RPM 825 O2 703 TPS .45 LV8 40 CTS 149 IAC 26 BLM 126 INT 128 MAT 52 Volts 13.6 O2 counts 0 Idling open loop Rich Thanks. Rob.
Dec 23, 2008 #2 T turbojd Well-Known Member Joined Dec 27, 2005 Messages 1,983 They don't look to bad.
Dec 23, 2008 #3 T TurboBuRick Moderator Staff member Joined Feb 18, 2006 Messages 10,084 X2 They look good! Just a tad high on the tps but nothing to cause real concern. Rick
Dec 24, 2008 #4 B bmackinnon Active Member Joined Feb 24, 2005 Messages 2,092 I'd venture to say PERFECT!! Now, how do they look WOT? :biggrin:
Dec 24, 2008 #5 K karst#9 Member Joined Feb 24, 2003 Messages 230 melrob94 said: How do these numbers look at idle and warm? RPM 825 O2 703 TPS .45 LV8 40 CTS 149 IAC 26 BLM 126 INT 128 MAT 52 Volts 13.6 O2 counts 0 Idling open loop Rich Thanks. Rob. Click to expand... What is MAT 52? Thats not MAL 52, calpack error is it? what are you using for a scan tool
Dec 25, 2008 #6 B bmackinnon Active Member Joined Feb 24, 2005 Messages 2,092 karst#9 said: What is MAT 52? Thats not MAL 52, calpack error is it? what are you using for a scan tool Click to expand... MAT = manifold air temp I think on SM (same as IAT (inlet))... cool day out I would guess... :wink:
Dec 25, 2008 #7 Chuck Leeper Toxic old bastard Staff member Joined May 28, 2001 Messages 16,704 "Idling open loop Rich"... Could be at the 149* water temp, the program is still adding cold start fuel?? I would not consider 149* to be "warmed up"...
Dec 25, 2008 #8 M melrob94 Member Joined Dec 14, 2006 Messages 161 Thanks for the comments. I am using Turbo Link. It was a cool day, the car was still warming up. It does say MAT 52.
