Russ Merritt
- Aug 11, 2002
JCotton said:One more thing, has any of you put a temp sensor before the intake, like somewhere around the outlet of the IC and gotten any data? I would suspect the higher intake temp with a sensor mounted in the plenum or lower manifold would tend to include some heat soak causing higher temps at the line, and for some of us, higher false temps the first 1\8th. It may not be much, but none the less data a little more accurate related to the efficiency of the IC.
Yes, both my cars have the MAT down bottom right after the intercooler.
92* at the start, 161* at the finish, first 2 runs, @ 26-27# boost
92* at the start, 171* at the finish, last run. @ 28-29# boost. Not an attack Jack, just the facts.
