Second guessing again....
Steve V
Steve V's Automotive 757 560 2782
I have the direct drum out and my band has a black spot in the middle and on the drum. The drum has a high spot in the center about.002-.0015. I am 2nd guessing my band clearence. Maybe if I shave a few more thousandths off the servo pin it will correct this with no ill effects.
Trans had a pump issue and It did flare in 2nd a few times. Heres a link to pics from a prior teardown when I smoked it. It looks a bit darker this time.http://www.turbobuick.com/forums/transmission-talk/283754-too-tight.html 600 miles since overhaul.
I have a freind with a lathe so I am gonna put the drum in it and sand the center a bit,maybe to flatten it some. Last time I did it by hand.
