self inflicted trans. prob.
kevin
i was going to get a bigger servo so i pulled out mine and the new one did not come in.so i put mine back in and now i have prob. with trans not wanting to shift to 2nd at wot.and if you are in od and give it half throttle it kicks down and slips.i pulled out again and found a seal nicked.i replaced and same thing.i looked again and no seals are damaged.i know i have it properly installed.checked 2 times.what the heck did i do?
kevin
Lip seals facing the right way on the servo? Are the sealing rings on the pin OK? Just a thought.
Jim
lip seal direction
The big lip seal lip faces towards the servo bore and the smaller lip seal lip points towards the servo cover.
Make sure your band pin is contacting the band too. :D
thanks guy's.i put the inner seal on the same as the outer.i'll change that and see what happens!!!
It will work now...
Bruce
WE4
PTS XTREME
