SignUp Now!What's up, Prasad? It's been a long time...
Anyway Cody and Dave beat me to this swap which was something I've wanted to do for at least 5 years -- but never had the money to buy the GN in the first place. But I'm glad someone I know did it and I'm happy to see the end results.
Kudo's to Cody and Dave for getting this thing done and to the track and putting down some impressive times its first time out. I think the Series 2 3800 could be the next big thing for the GN community -- at least for those wanting to take the technilogical leap in updating their cars. I know it is the FIRST thing I am going to do once I get a GN. I've already done it to my Fiero...
-ryan
How are ya'll getting around the 1 bar MAP in the L36 ECM?
Any pictures of the oil pan to frame area and how tight was that? Which pan did you use?
That sounds like too much work considering you could have run faster for less money using off the shelf parts.
These pcms dont look at the map sensor unless the maf sensor fails, then its moreless a failsafe sensor to run in speed density so the car will at least run. All fueling is strictly referrenced off of the output of the maf sensor unless it fails or is unplugged. The oil pan I use is for an F-body car which fits the frame very well. There is probably about 1/4 to 1/2" in a few spots of clearance so there isnt room to move it forward without modifying the pan but it sits in a good spot and wont hit.
its hit or miss with the Fbody some car need the VE tuning (for just driving around) and some don'tDepends on the PCM unless all the F-body stuff doesn't have the VE tables enabled like some of the FWD stuff does. Using 98 F-body cable throttle PCM? Big discussion going on over on the HPT board about it and the plans for HPT to unlock the switch so we can turn them on and start tuning them.
Would you mind posting some pictures of how you did the cooling system? From my L67 W-body days I'd like to see how you got the cooling system all linked up with that manifold.
Very nice work guys! Gotta know, cold a/c and cruise??? I really hate it when guys gut this stuff. I think it ruins the whole fast with class thing. Dave
The blocks are the same best I and anyone else I've talked to know. The bellhousing is Metric 60º V6 like the 2.8/3.1/3.4L V6's found in the older F-bodies. The 4.3L uses the standard C bellhousing like an SBC, you'd need the bell from an older 2.8L S-10. No idea on the oil pan clearance or if the F-body manifolds will clear. Lastly you will need an F-body 96-98 intake and a 98 PCM because the 99+ are throttle by wire.So are the front drive blocks and the F-body block the same??? And what bellhousing pattern is needed to bolt up to it??? Let's say I wanted to swap one of these(NA though) in place of a 4.3L in an S-10 with a 5 speed, could I use the 4.3L bellhousing or would I need to find a different one???
Oops...Sorry to hijack the thread...Great job on the conversion...I had always thought of doing something like this. Just not enough time and money. Get the shakedowns out of the way and really hammer on it to see what kind of times you can get!!!![]()
Great work, guys! Those numbers on a "shakedown" are amazing.11.357 @ 121.40...Boost is around the 17-18 mark, timing is a steady 18 deg and AFR is mid 11s the whole run
