- Feb 14, 2002
Cool swap! I like it. I don't know much about L67's but it obviously runs very well! All Buick all the way.
SignUp Now!I personally watched Steve from the board here run 10.6x on 275/60 drag radials in a full weight T-type driven to the track using a te-45a (similar turbo) with ported stock heads, stock block, stock crank, stock rods, and a 206 flat tappet and most importantly didn't have any custom made parts. The next owner went 10.5x. I'd be willing to bet it didn't cost any more than using a series 2 engine, everything just bolts together with no modifications, and when you factor in all the time making custom manifolds, downpipe, plumbing, etc. and gathering the parts to make it work and not being able to order a commonly available chip. I don't see any conceivable way you could say this is cheaper.
I still think it's pretty cool that you were able to get it to work and use an engine you can still find anywhere though.
dont need a full cage until 9.99 only need bar if slower then that
The SeriesII engines still have only 8 headbolts per side right? I wonder if the really fast guys have head lifting issues like we do with the 109 motors?
thanksYa, but... Im one of those guys that never stops modding... this week it may be 9.99... but next week that 8.50 certification might come in handy lol. Either way, this is a way cool car and it actually makes me want to get a damn 6er f-body like yours and build a killer sleeper setup and go win some cash![]()
The only trick for me would be making the turbos quiet enough to not get noticed lol...
Im stoked about all of this because my new shop is opening up on friday! We are going to be rebuilding salvaged late model bikes(mostly cruisers) and building what we call "working class customs"... this also gives me space to bring my GN up here to college with me
either way I have "seen the light" on these late model 3.8s and Im pretty stoked! Is there a turbo 6 fbody forum around or any good places to read up on other peoples setups?
the Fbody that intense made is running just 8 studs and he runs 8.90'sThis is another area of concern but when the Cometics became available it helped out a lot of the 20+ psi builds. A few guys have even drilled and tapped addtional holds in the head and block to add extra clamping force towards the outside of the head and block as it seemed that since the area was somewhat then here it was a potential leak area but I also know there are cars running mid to high 20s with a good build and not using the extra bolts without problems. I guess its hard to say since the hardcore guys take the car to the track only a few times a year and I am more of a daily driver guy that wants real world results and requirements but I have not experienced any problems with the head gaskets blowing out yet though it certainly does happen.
ZZP has a stock bottom end L67 running low 9 so they should hold up just fineI just want to see this idea progress and be pushed further. THere's a whole new aftermarket out there just waiting for a fresh idea. God know's there's plenty of those motors out there to begin with. GM knew what they had there, and they tried to put it in every vehicle they could. Just a great motor. But how it will hold up when pushed past it's original design limits...we shall see. KEEP IT UP!!!!
I also know the L36's in the fbody can take a beating too (one fully stock motor guy is running 11.6's)
So are guys keeping the balance shaft or getting rid of it? The old "better balance, smoother, makes more power vs. lower rotating mass" thing.
if the motor is ballance you dont need it and many many many guys are runing with out hte shaft its just 5 lb of wieght you need need turning around lolI try to keep the balance shaft in there and working any time possible. It really does help make this engine run smooth. But all of the aftermarket "heavy duty" timing chains I have seen that you are required to run when using large camshafts (because of the stouter valve springs required) don't have provisions for running the balance shaft.
plpus with that big a cam who cares if it vibrates a little![]()
