jhanson1750
just a 10th quicker
- Apr 24, 2005
Not sure about GNs but on a FORD 8.8 or 9" there is a Master Head Dimension (MHD). That sounds like what you read on the pinion and then verified with mics and math. This is the depth the head of the pinion should be away from the CL of the Ring. If this is a known value then setup is quick. There is not a car company out there that can lose that kind of time per unit. Look like you are a compitent machineist and will get it done. WOW I was told to use anti-seize the first time I ever set up a gear set.
Ps. On the crush sleve I always mic the old one and then get the new one to "start crushing" in a vise or press just don't go to far. When I put them in they are smooth as you could hope for on the drag setting. Jon Hanson
