Cheeseburger
- Jan 25, 2004
Well i am trying to figure this out, i have all but one reluctor off the reluctor wheel, the advance is locked out.
I read that you need to drill and tap for a set screw on the reluctor, mine is factory siliconed? in place and there is a keyway on the shaft, do i need to break the seal and move the reluctor at some point?
The more i read about this the more i seem to get confused................
Step by step procedure would be great as this is my first attept at installing a distributer and msd crank trigger wheel set up.
Thanks in Advance.
Thanks in Advance.
