Sheet Metal Trans Pan ?
jmendlik
Anyone ever seen this type of filter used with a custom Aluminum pan? Is this is one of PTS Extreme bottom feeder set-up?
I may purchase this pan set-up for my 200-4R trans.
Where can a new one ( Filter) be purchased ?? Got a part number on this filter?
JM
Yes, same setup I run
is this worth $200...on a flat surface it does rock a little so it needs to be worked on to be flat/ture
I'd say it is. You have to watch your ground clearance with it but otherwise it should be fine. The only thing that has to be flat is the gasket surface.
Never had issues with mine omas for ground clearance.
Imop that looks similar to the one bruce sold but from the looks of it that looks like a copy.
That’s not a Mopar 727 filter. It’s a General Motors 200C filter
Well I'll be damned. I didn't look that close at the second pic I just knew most of those setups used the mopar filter. You appear to be correct sir.
