My car did about the same thing a couple of weeks ago. Low power and wouldn't build boost or RPM in lower gears. WOT fuel setting was adding 7% additional fuel. Put that back to 0 and car came back to life.
Pull a plug and take a look at it. Will probably look like it was dipped in carbon black. If so, here's what I would do:
Set FP to 43#. (You can test the FP by turning on the key and cranking up the regulator to 70#-80#'s.)
Set all TT chip settings to Eric's default settings. Make sure fuel matches chip
Double check the TV cable setting compared to current setting
Check the insertion of the PL board into the ECM. Double tape it if needed.
Drive it around a while and, if it cleans up, runs well and is responsive, I'd find a place where you can safely make a good WOT run so you can log data from 40 to 100 MPH. I'd make 2 runs and then post them here.
You should not been running out of fuel with 60# injectors. Could be
the chip doesn't match your combo
fuel used and chip are not compatible
fuel pressure isn't set correctly
fuel pump is NFG
fuel filter is clogged up
I've dynoed mine a few times and I don't have a great deal of faith in a shop sensor stuck in the tailpipe.
Go here and look under Buick 2004r and you will get instructions to adjust the TV cable. http://www.tciauto.com/Products/Inst...ns/default.asp
fuel pump is NFG
