turbo96max
- Jun 6, 2007
I just finished  fixing my blown head gaskets. In order to removed oil pan I lifted the engine up (bolted to tranny) about 5 inches, and I didnt remove the linkage from behinf the frirewall. Now that I am pulling the car out of the driveway, it shifted into revers np, then n, then d. but when i try going up from d to n and to p, i have to force  the shifter and sounds like a grinding noise. I played around with the adjustment of the rod (FIREWALL) nothing doing. I am wondering if the cable for the shifter may be bad somehow? could i have bent something else? could the actual internals be hurt? could the cable need adjustment? rods maybe bent?
im thinking since it goes down just fine, the rod should be fine. im leaning towards maybe part of the cable broke and it kinks up against the cable tubing only when going up, agains the grain of the cable somehow??
any one got any input? im thinking that i will look for linkage rods inthe junk yard tom. and see what happends??
thanks in advance
thanks in advance
