Falken Azenis 's 295/40/18 out back,255/40/18's in front,Aerospace pro-street disk brakes all around with parking brake for 9" ford rear (Currie with 3:20 gear),BMR control arms upper an lowers front an back,urathaen bushings all around less bronze bushing in upper rear front a-arm,(so i don't melt it)bilistein shocks,28mm rear sway bar,22mm front adjestiable on hime joints,ebich 1" drop sport springs,(which are to soft in my view,i'm putting rate springs back in it) GNX flares (adding the functional luver kit too)..It will not slide out at all unless i stab the gas (stock block, 700hp) by then your already on your way out a side window...
...I had a blue suburu with hood scope try hang with me in long sweeping hwy on-ramp,faster i went there more the suburu was sliding out behind me!
I was just looking for tires and that is a sick set up. I'm running nitto 555's and took it to the road course today. I'll just say that tires are now a MUCH higher priority! You didn't have to trim anything?!
