bitchin_buick
Cragar Keystone Klassics
- Nov 11, 2008
Had I not been hardheaded and asked for help 3 weeks ago this story I'm sure would be alot shorter. Around Thanksgiving dailydriver all of a sudden didn't want to start right (sounded like missfire-seemed to have good cranking power) Once up and running seemed ok... Changed fuel filter, checked fuel pump(working), changed plugs and boots,cleaned up all cables/grounds. still had problem. Replaced Ignition coil module, coil packs and housing(was cracked). still sounded like bad missfire problem and new intermitten problems while driving. Replaced fuel pressure regulator... Yup still had problem!!!! New T.P.S.--STILL had problem....Exhaust cracked at manifold(thought maybe lowbackpressure) fixed- still had problem... Engine light finally stayed on long enough to get a proper diagonstics, came up Cam sensor and Crank sensor.... Yup I replaced those also. Still had the problem! Noticed the other day my coolant fan came on as soon as the car fired up and it was 9 degrees out. Today it is 55 ran car for half hour sitting in the drive and fan did not come on but the car started better??? I'm thinking I may have a major wiring problem/main computer or fuel pump not putting out enough pressure. Dont want to drop the fuel tank and spend over $200 bucks if it isn't the fuel pump. I think I have more than one problem and everytime I troubleshoot and think I have have figured it out I end up back at square-1. Very frustrated!!!!!!!!! I have spent 60-70 hours working on her and nothing!!! I'm probably forgetting some $5.00 part that takes 2 minutes to fix and here I am being hardheaded and over $600 in the hole! Very pissed for not asking for help sooner!!!!!![Mad :mad: :mad:](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
