Only thing that doesn't make sense to me....the MAF pipe I have is a solid piece. The S shaped tube coming from the oil fill tube is not connected to the MAF pipe or anything. It's wide open in the engine compartment. In fact, there is some oil on the chrome MAF pipe that has blown out of it. I wouldn't think I have that much crankcase pressure if that tube is wide open. Could the intake gasket be leaking into the lifter galley under boost?? I did have the PCV valve blow out of the intake once...but it only happened the one time, and my setup hasn't changed.
Could someone post some pics of the options for routing the PCV and breather options?? Thanks again guys. ---Keith
I think you may possibly seeing two issues:
1-Smoke at start-up.
This "could" be "valve guide" related, or oil in the combustion chamber related that makes it past the rings.
2-Oil out of the breather.
This is more than likely crank case pressure related.
I agree, ring "should" have seated. - I had one motor that the rings never seated after 1500 miles. LOL!
It was smoking to my continual embarrassment! :biggrin:
That is when I learned the negative affect on octane from oil.
Disconnect the WG, and drive it around, no boost (!!) and see if there is oil on the breather.
If "Yes", possibly rings (Or HG)
If "No", possible intake leak.
PCV is probably not going to solve the problem.
