86 got boost
- Mar 17, 2005
fresh rebuild, started, ran for 30 min, at 2500 rpm, yes flat tap cam, she pumped smoke pretty bad for about 15 min. then cleared to a small bit, and when shut down than restart, she puffed...
Next day changed oil an filter. started. smoked and smoked, but I started losing fuel pressure, no fuel, my sender off... so shut down and said WTF!
I pulled all the plugs, not one of the plugs were wet and when I looked in the cylinders, the dish on diamonds had a little oil settled in them... not pooled dont get that wrong, checked oil stick was half a quart over, drained access to level.
been goin through all the forums and heard some things about the intake gasket not clearing the spill off from turbo and splashing on top and getting sucked by the PCV... and PCV being bad, have not checked that issue goin to plug after I get some GO GO JUICE:biggrin:
might have to pull valve covers and see if one of the seals popped, and can I change seals while heads in car, guides have been machined for seals and there stock heads...
