Anyone on here have any experience with the Snow Water/Alky MAF based injection system???
GNX405 finally got a WOT pull recorded on DS (his 87 Mazda LC2). It has this system on it. It uses a mixture of water/heet. 2 cans of heet to 1 gallon of water (actually -20° windshield fluid), and this mixture added to the somewhat smallish reservoir.
Here's the issue. The car seemed to pull real hard with no apperent issues, until we looked at the DS scan. During normal driving the O2 volts look normal (stock NBO2). But when going WOT the O2 volts drop into the 020's
and stay there during the entire WOT time. At the end of the run the O2's return to expected readings.
My guess is that the water/heet(source of meth) injection is causing the wierd O2 readings, unlike pure meth injection.
For the particulars it's a moderately(internals) built LC2, with 55's, TA6(something) turbo, TT alky chip (too much timing I think), and Translator/LS1
He'll have to pull some boost out which he did. Haven't heard back but I'm hoping he's now closer to 17#.
I also suggested pulling the boost way back and shuting off the Snow inj. and see what the O2 did, but I'm not sure how low he'll be able to get the boost. The TT alky chip is indicating that it is defaulted to 23° timing
Definately got some tuning to do! Good practice for him. :wink: :wink:
But the original question.... Lotsa water/little alky... is this what's causing the O2's to drop in the 020's during a pull? I doubt that they're really that lean or it would have blown both heads off. It was running 20# boost during that pass and only recorded about 5-6° of KR at the 2-3 shift
I have absolutely no background in water injection to draw experience from.
And only 3rd party info on actual meth injection.
Help guys!!
Help guys!!
