SignUp Now!oil has no coolant in it ever. bronze gear. roller cam, 40 psi hot at idle. I dont know what type of pump/spring rpe uses. if pvc is overwhelmed what can i do??
I had to run an oil line to spray my cam gear on my billet roller cam. There isn't a passage to feed oil to it like the stock cast cams. May want to look at that. Also, is that an aftermarket front cover? Might not be machined just right.
I didnt have coolant going into the oil. Everytime I built boost I would burn it out of the exhuast. #6 plug was wet. That must be condensation , I might not have enough venting or possibly the pcv valve needs to be replaced. May I ask where you bout that gear?? I need oneYou defiantly have a coolant leak. Thank your pcv for keeping it out of the oil.
I just switched to composite gear. I have a few hundred miles on it now. I been meaning to pull it out and see if any of wear. Let me get a cup of coffee down and I'll yank it.
For the gears to live the cam needs end play and some type of oil feed. They say .005 - .010 end play. IMO the high side is more forgiving. A small hole can be drilled in one of the oil gallery plugs .020.
