Solid Roller Cam Nose Bolt torque.....
Cheeseburger
Can't find my notes from a few years ago and need the cam needle bearing thrust button torque spec.
T.I.A.
60 seems like alot, i torqued it to 35 ft lbs for now which seemed like a ton for that bolt.
Needle bearing thrust button, 40-55lbs according to my manual.
Loc tite. Don't hammer the bolt down with an impact or it might crack the fp eccentric of you're using a cast one
loctite and 50 ft-lbs. ive seen the damage a loose one can do when it screw-jacks a front cover off at 6000 rpm
The spec from a 1977 odd fire motor is 31 ft lbs.35 would be ok too with RED loctite.
