- Mar 1, 2005
O yeah and that is me yelling 4.92:biggrin: :biggrin: :biggrin:
SignUp Now!O yeah and that is me yelling 4.92:biggrin: :biggrin: :biggrin:
A follow up since Im home now.
This was at 24 PSI (REALLY 24 PSI, not Buick Fantasyland 24 PSI) with the EGTs about 1050 at the end of the run. We think the motor wants more timing and it certainly wants more boost.. We probably need a slightly lighter spring in the rear, too.. We had another set but didnt change them. I think we may add some weight to the back end because there really isnt anything back there now except the battery.
75 Borg's!
75 Borg's!
Holy Crap!! that's going to be one bad a$$ runner when tuned in!!!!
BTW, Shane what's the full designation on the 75's? I'd like to see if my Son-in-law knows them. He's a turbo design engineer at BW over in Ashville.
If they put out what they are supposed to he won't need bigger onesGlad you like the Borgs. Let me know when you need bigger ones :biggrin:
That would be awesome!I think he was referring to when we put a BB in!
The plugs have no burn marks on the base or threads. The timing mark is still on top of the ground strap. Way to much fuel in it for now. On the dyno it only made around 800 at this boost level. With 12 psi on the launch and 24 with in .5 seconds. These turbos really shine above 30 psi. We are using tires from a car that runs 4.20's with 30 runs on them. they replace them at 25 or so. It does like timing at this level. drop a degree or two and power falls way off. We are adjusting the tune and chassis. Installed lighter rear springs and adjusted shocks. The video was at 5500 rpm launch will be higher next time. Wheel speed is still slow through .75 secs. Needs more power earlier in the run. And we had snow flurries today. It will be a week or so before the weather clears up. We are hoping to go to VMP as soon as the weather allows. Or a trip to southern states may be needed. We got the shifter problem fixed today, A problem with the shift box. Trans has good pressure and convertor looks like it is on the right track.
Dave they are the S400Sx's. He will know the complete line just off that naming system. Direct part # is 177101 for that particular unit. We keep them in stock with our Turbodiesels.net shop.
You may find out that you don't need to launch at a higher rpm as you lean on the mixture a little at a time. If you're that rich, there will be plenty of power on hand as you lean on it. Just keep a sharp eye on those plugs. They are your best window into the engine with alcohol.The plugs have no burn marks on the base or threads. The timing mark is still on top of the ground strap. Way to much fuel in it for now. On the dyno it only made around 800 at this boost level. With 12 psi on the launch and 24 with in .5 seconds. These turbos really shine above 30 psi. We are using tires from a car that runs 4.20's with 30 runs on them. they replace them at 25 or so. It does like timing at this level. drop a degree or two and power falls way off. We are adjusting the tune and chassis. Installed lighter rear springs and adjusted shocks. The video was at 5500 rpm launch will be higher next time. Wheel speed is still slow through .75 secs. Needs more power earlier in the run. And we had snow flurries today. It will be a week or so before the weather clears up. We are hoping to go to VMP as soon as the weather allows. Or a trip to southern states may be needed. We got the shifter problem fixed today, A problem with the shift box. Trans has good pressure and convertor looks like it is on the right track.
