- May 27, 2001
Trackside posting...... First full pass car ran 4.92 @ 138 with a 1.14 60 foot.
SignUp Now!Trackside posting...... First full pass car ran 4.92 @ 138 with a 1.14 60 foot.
So what happened on the other passes
A follow up since Im home now.
This was at 24 PSI (REALLY 24 PSI, not Buick Fantasyland 24 PSI) with the EGTs about 1050 at the end of the run. We think the motor wants more timing and it certainly wants more boost.. We probably need a slightly lighter spring in the rear, too.. We had another set but didnt change them. I think we may add some weight to the back end because there really isnt anything back there now except the battery.
We made a little short blast before the lights and computer were hooked up. The second run had a shorter burnout could have led to the spining in second gear. Not sure why it did not shift into third. It put out number 1, egt went cold. It started to come back but lifted at 3.92 seconds into the run. Thats why the mph is down. The weather for the next week are so will not be good for testing. The convertor change is in the right direction, but need to get to a track with some traction to test it in high gear. 60 degrees track temperture is hard to get a hold of. We will make some adjustments and try it as soon as the weather lets us.
