gnpoweredrail
- Mar 22, 2010
Whats the tightest gap you have ever run?? Why did you run the little gap in the first place?
SignUp Now!^ whats the problem? if spark blow out at high boost and RPM gap the plugs .02 tigher and try again. i would also check plug wires and coil as well
The loosest ive gone with anything over 500hp is a tight .028. .023-.025 on my black car. If your making some power and start mis-firing under power you will hurt it.
^ you more then likely didnt hurt anything.
Not sure on your setup but how much boost? what cam?
also a set of NGK UR5's would work well. If you want delco get AC CR42TS
I would check plug wires. gapping tighter will tell you if its spark or not. even a weak coil pack could cause poping.
