scot w.
GNSperformance.com
- Feb 19, 2005
Okay I recently have been thinking about spark plugs and what happens in the cylender when using Julios AKLYCONTROL kit along with regular 93 gas. Does the alky kit make things hotter, make things cooler or pretty much remain the same?
The reason I ask is the Correct heat range and type of spark plug is a vital part of the "tune" of an engine combustion. The tip temperature of the spark plug must stay lower than dangerous Pre-ignition temperature of about 1400* F.
The tip temperature must also stay hot enough to prevent oil or carbon fouling (apoximetly 800* F). So although it's a good rule of thumb to maintain the hottest tip temperature possible that will not cause problems, What plug is recomended with using the Alky kit with 93 octane gas??
Has this been researched?? Be curious to know the findings on how or if there are any changes to the combustion..
Scot W.
Scot W.
