Spec my cam please! 4.1 N/A build
jdpolzin
So I've been doing some playing around with a couple different N/A builds in the past 10 years and haven't quite got anything done yet to be honest!
I need some help. Been reading about some of your different cams. Im seeing you are having roller cams made to spec from some of the older flat tappet specs for N/A builds. I have a 4.1, basic bottom end rebuild, im guessing high 7s compression pistons. Ported irons with PAC 1283 springs (see specs below, set up for a roller). Ill be using a 2004r out of a Monte SS, a red Stripe converter (restalled D5 2600-2800), 3.73 posi rear, Hooker headers, and a Quadrajet off of an 89 307 Olds motor (electric choke). Plan is to use a factory 87 non turbo engine harness and ECM if I can. Would like to street drive it regularly, but want some lump to the cam even though we all know most people dont like the v6 sound! As far as performance goes, I realize this won't be great but im trying to get the most out of it without ruining drivability.
So with that said, can you guys guide me towards a roller cam? I dont mind getting one custom ground.
As far as an intake, I have either a Weiand or a stock 4 barrel intake to choose from. My other NA build is quite a bit more extensive so id prefer to keep the Weiand for that, but I dont mind using it if I have too. Could probably pick up an extra at some point im sure.
Heads are old school, but very nicely ported ATR heads. I do have H/S roller rockers (1.60) to use on them as well.
EK02 gave me a camshaft to replace the Kenne Bell XP1 cam that was in my +
.030 over 3.8
This version was flat tappet but would be a good candidate for a roller grind.
Elgin Prostock 998P
214/224 .472/.496 lift.
The other camshaft bigger than this could be used. I'll add the catalog from 2022
.030 over 3.8
Elgin Prostock 998P
The guides are machined on the heads so I dont mind using a tall lift if itll help me. I remember the 214/224 being mentioned quite a bit in the past on a an NA. Im wondering if anybody has used it recently with succes?
The Impulse is one of my daily's I spin it high it pulls all the way to the top. If it has boost it would be really good, I have stopped myself from pulling it out and stuffing it in the blowthru Regal.
The Kenne Bell mark 2r cam is what we/I want. EK02 had a roller version of it made and he sprays N2o on it.
