Specs on a GTB6131E water cooled turbo
jmidolo
Sexy MF Joe
Just bought a car with a GTB6131E on it. Can anyone give me some specs on it?
Great turbo, alittle bigger than stock. Will be good into the 11s
What specs are you looking for?
Compressor map?
Believe it's rated at 620hp
H61 6 blade with a T31 exhaust
Compressor map for the 61 is online.
61mm comp wheel, most likely a journal bearing, good for 63lb/min when pushed, will spool with a large range of converters, ideal with a 2800 9.5"
GT35r compressor and t31 stage 3 exhaust wheel
