Sportsman First Impression
Discussion in 'Performance ECM Upgrades' started by 84BuickGNYorkPA, Sep 3, 2017.
  1. 84BuickGNYorkPA
    84BuickGNYorkPA
    Expand Collapse
    Daily Driving Buick V-6 Turbo's 1979 - Present
    Jul 5, 2005
    1,788
    80
    Offline
    1) The installation was straight forward with the help thread. I let the IAT temp where it was for the turbo tweak chips which is before the alky spray. The Sportsman will tune around it no problem, next time I pull the intake I will put some NPT holes toward the fire wall for a few sensors and vacuum lines.
    2) Ok you will need Cal for the startup run down as there are several areas to verify and address. Starting with the communications with the laptop, very easy, very windows oriented software! Checked for any faults. After about 10 minutes we were ready to turn the key on.
    3) It started right up!!
    4) With Cal on the phone we got the idle tuned in pretty quickly, just had to wait to see what it looked like warmed up and both in gear and Park.
    5) Still with Cal on the phone we started right in with the fuel table at just above idle 1st row and then again on the 2nd row, bam that's pretty much it. After that the Sportsman will adjust the fuel table from there!
    6) The edash has a crystal clear screen not sure on the dpi but no complaints here.
    #1 84BuickGNYorkPA, Sep 3, 2017
    • Like Like x 1
  2. 84BuickGNYorkPA
    84BuickGNYorkPA
    Expand Collapse
    Jul 5, 2005
    1,788
    80
    Offline
    Update: The help page in the FAST program is very educational, I have been logging some pulls and adjusting base fuel cells, having fun with it...
  3. 84BuickGNYorkPA
    84BuickGNYorkPA
    Expand Collapse
    Jul 5, 2005
    1,788
    80
    Offline
    Update: The car is running great, knock alarm never goes off, 22.31 mpg on the way home from the game Saturday.....This is my all time best mpg in 140,000 + miles of driving the car. I need to get to the track or a dyno and work on the top end tune... still have much to learn...
    Chuck
  4. TURBOTIMMER
    TURBOTIMMER
    Expand Collapse
    Jan 5, 2002
    831
    100
    Offline
    Good info. My sportsmen is still in the box. It'll be a winter install.
  5. huntsg
    huntsg
    Expand Collapse
    Aug 10, 2009
    745
    68
    Offline
    22 mpg is impressive. I get no where near that. I don't get on the highway much so it is mostly around town, but still that is really good.
  6. HighPSI
    HighPSI
    Expand Collapse
    Moderator
    Staff Member
    May 24, 2001
    5,289
    292
    Offline
    Those are great numbers. What's your Target A/F ratio?
    Sent from my SM-G955U1 using Tapatalk
  7. 84BuickGNYorkPA
    84BuickGNYorkPA
    Expand Collapse
    Jul 5, 2005
    1,788
    80
    Offline
    15.3 a/f ratio and bumped the timing up one degree in the cruise area only. I’ve since taken the a/f up to 15.5 with no issues.
    • Like Like x 1
  8. 84BuickGNYorkPA
    84BuickGNYorkPA
    Expand Collapse
    Jul 5, 2005
    1,788
    80
    Offline
    Thanks I was totally happy with that highway cruise on a non lock setup. But around town I can’t get above 15 but then again I don’t expect to either. [​IMG]
  9. Instro84
    Instro84
    Expand Collapse
    USAF retired
    Jul 17, 2005
    1,652
    107
    Offline
    man i'm tempted, if they go on sale again may have to pull the trigger.
Share This Page
