I had to rebend the 1/4" line that comes out of the prop. valve to the rear and doing so i needed to shorten it up some now here is the issue i tried using my double flare tool to put the same end back on and no matter how tight i got the clamps it would push the tube before making the first step for the bubble. I ended up just doing a single flare that SS tube is way to stiff! Will this work fine or should i find a better flaring tool i have a decent snap-on tool that works fine with soft metals? Also is the factory type double flare a 45 degree?
Chris
Chris
