FreddieWilliams
- May 26, 2001
I have a couple of questions to ask:
1.) I have heard of the requirement of "on center" stage 2 motors needing to have a stock front cover milled ~ .120" to allow the cam sensor drive gear to align properly.
Is this the same for a "off center" stage 1 block using a stock front cover?
2.) The issue I ran into today was that my BMS balancer interrupt ring is hitting the front cover and also bottoming out into the crank sensor.
My cam sensor drive drops right in and looks to be aligned dead center. I'm using a stock front cover gasket (very thin compared to the paper Felpro unit).
I determined the balancer needs to be shimmed out by ~0.125" to clear the cover and sensor. This of course pushes the crank pulley too far forward.
I figured instead of shimming "all" the other pulley components to get it to line up with the new crank pulley position, to just mill the pulley face down on the balancer by the shim amount (.125"). This will bring the crank pulley back in alignment with all the other pulleys without any further mods.
What do you guys think?
