They had to be in the 50's to get it to idle at 13.5, but then it would lean out. Don't know what the pw is at idle, never looked.
Does anyone have a good starting point for injector offset vs. batt voltage for a green top 160? This is what I have now. It was in the 350tb160.gct in the example programs. I'm not sure I understand what this does, I don't remember seeing it in Classic Fast. Does it add that much pulse width depending on battery voltage?
Yes, it will add back the dead time of the injector. Have you checked the .ict folder for the correct injector?
Classic fast had a fixed battery offset table that would be multiplied by the injector opening time setting in operational parameters.
