BLACK MAGIC RACING
formerly turbo_canuck
- Jul 18, 2001
I have a stage 2, 274 off-center 4.1 block, 274 c.i.d. Champion gn 1's, pt-70gtq, 95 lb injectors. just waiting for some time off to go to jack cotton's for the FAST install. in the meantime, using a t-plus with extender extreme chip. the cam is a hyd. roller, 218-212. i'm thinking this is a bit small for a big cube engine... as the motor only pulls to about 6000rpm. is the cam in this block the same as a 109? are there specific cams for on and off center? would the stage 2 cams listed on comp cam's website work? or would they be too big? the smallest one is a 264-268, 650 lift. any suggestions would be appreciated.
