Stay tuned for some interesting Dyno tests.
Hard to say, I have a car that put down a conservative 604 at 28#s with a 6776, though i think the 6776 is done where the 6765 has more left if cranked up
Car #2 put down 605 at 5700 today, torque was 586 right out to 5500 or so,boost at 28#s, pump gas, dual nozzle ALKYCONTROL.
The injector duty cycle according to the XFI was only at 55% with a single Aeromotive intank pump.
Tune is conservative at 18* timing a/f in the high 10s
With the new PTC convertor installed the dyno showed an improvement
of 16 MPH at 5700 RPM.
It was still picking up 25 RWHP per # of boost but being the short block is all stock components i stopped at 28.
We are thinking about putting in C16 and turning it up ;)
Not sure I can recommend that :D
Car number 3 is coming up.
I hope to have it running by next weekend,but it is a bit of a project and I am waiting on parts.
There is a car added to the mix though with a comp turbo 72MM Xtrim that may get a new Precision unit,not sure on the change yet,but will be doing back to back PTC convertor replacement on this car also this week.
Don't be a sissy Otto- turn that sucker up! Put some C16 in there, set the timing at 21*, turn the boost to 30# and let it eat. It'll survive one pull............You are a good tuner aren't you? ;):biggrin:
LOL, I am all for it Will, but the owner bought the car stock and dropped it off,he wanted to drive and enjoy it a bit before we really let it eat.
It is going to JW Racing and Fabrication soon for a mini tub,cage install.
He bought the aluminum budnik wheels,10" for the rear with 325 50 radials.
Trans is all stock with a shift kit/servo/PTC convertor,its on borrowed time...
Pretty nice dyno numbers! Do you think it would last a couple of passes like that or would you turn the boost down some?
HTML:
It could last years like that or 300'. You never know what you will get. The stock shortblock will take it for a while. You don't really know how hard it was run prior to cranking it up. If it was reltively stock/low rpm and not detonated it would likely stand a chance at lasting longer than one run in the grenade mode for years prior.
Over 600 ponies and only 55% of the 83's....can that be right :confused:
LOTS of alky......
So the hotrod fuel pump is not being worked very hard..?
Bob
Car 3 is on the dyno and OH MY!!! This 6265 is a BADD MOTHER on this RPE stroker!!!
I second that. Now turn it the F up and report back........:biggrin::biggrin:
Is 22#s considered turnned up??? :D
I stopped at 22.3#s because it already was making 612HP to the tires, and to make it even sweeter, the motor only needs to turn 5400 RPM to do it:eek:
This will be the funnest street Buick I have put together,it spools FAST!!
:d
Do you got any track times to compare your dyno numbers too? Just curious. Also, Have you pushed one of the aeromotive pumps yet without using alky?
