Steel shim headgasket re-torque question
TurboBob
Resident mad scientist
Staff member
I recently "loosened" a headgasket and need to retorque. I am running stacked shims with GE-1200, the old Jay C. recipe.
You other guys that have used this combination, which bolts tend to lose torque? I assume its the gasket deteriorating, and needs to be snugged down, but I am curious if its the top row that tends to get loose, or the bottom.
I am currently using torque-to-yield bolts, torqued to 87 factory specs, and the gaskets have been solid for 4+ years. I just want it to last another season of street driving.
I am planning to replace the bolts with studs, any suggestions from the collective wisdom of TB.com?
Bob
im running the same just retorqed last week the top row was the ones that were loose for me but i would do them all. i am using arp bolts
