Jackie grabos
- Feb 2, 2011
ok, just got my car back from the shop. had iac valve, oil pressure sender, ps pump, lower rad hose, valve cover gaskets, oil pan gaskets replaced. i had stock manifold put on to fix exhaust leaks, walboro fuel pump and hot wire, air leaks at maf sensor and vacuum leaks fixed or installed. the car runs like a different car, turbo spools good now and runs way better. only problem is car is running hot. i am in houston so it is over 100 heat index everyday. i have extender chip, front mount intercooler, new aluminum radiator and dual spal fans. i have installed 160 degree thermostat. car does not run above 180-185 when sitting after start up after 20 min. fans are coming on at 170. the only thing not replaced is water pump. wouldn't it overheat sitting if water pump? how do i tell if head gasket is bad? i have read this is a symptom. surely they would have caught this at shop when evaluating car? it is a reputable shop, any help appreciated. hoping it is just pump. found one for 40 bucks and going to try to change this weekend. sucks to get the car finally running right and cannot drive it.
