Turbo1dr
9 Sec Wanna-Be
- May 25, 2001
Couldn't edit my last post sooo...
Check to see if the valve stem seals are riding up on the stem of the valves. This will cause boost pressure to travel up the valve stem and put crankcase pressure in the engine which, in turn, will cause you to have excessive blow-by under boost only. And on top of that, the car may smoke at an idle due to valve stem seals not sealing.
